I have a comp vs cam and its throwing 2 codes, 0300 i think which is multi cylinder misfire and a 14 something which is emmsions control, now is it the cam doing this or is something wrong with the car? how would i fix it?
cam throwing 2 codes
Thats the same cam I put in , the PO300 is it flashing and on the other code is it PO1441 incorrect purge flow?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Its a evap code incorrect purge flow, it is located on the upper intake manifold pass. side in the back. Mine was a loose wire which would come on( not too often, maybe 3 times a year. It is for emmissions and I would not worry about it if you reset it and it doesn't come back. I had misfires too, and it was a coil and a injector.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
