I have the maft+, but I do not have the ICM portion connected at the moment, only plugged into the maf.
Right now, I have wot set to 4% lean, and am not seeing much difference in O2's. Though I will admit I do not have a good wot run to look at. I seem to be hanging around .900
I would like to know what everyone has their maft set to at wot? I know its not going to be exact, consider this a survey.
2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
<blockquote>quote:</font><hr>Originally posted by strobhen: I would like to know what everyone has their maft set to at wot? I know its not going to be exact, consider this a survey.<hr></blockquote>
Mine is set to 6% lean (wot), and it's still just a little rich. Still need to dial it in exactly. That is with upgraded 24 lb injectors.
Base is zero. The pcm learns out the base, but it takes time, so it is very misleading to play with the base setting because your readings will be different right after the change than they are 20 minutes later, or 3 days later.
