Ever since i had the pcm programmed with the shift points raised my car doesnt seem right. Its hard to explain but here goes. when i go wot the engine screams but the car doesnt seem to be moving as fast as it should according to the sound of how high the engine rpms sound, is this normal withe programming?
did programming mess my car up?
You really need to narrow down some of the other issues so we can help you. Have you Autotap'd the car? Any knock retard? What are your fuel trims at? O2's? It'd be great if people could help everyone with a problem after simply hearing "my car is running good", but it isn't that easy.
"Help me, help you." - Jerry Maguire<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Is your tranny shifting crispy at the higher rpm? ... or do you sense some slippage?
... more so, what method did you use to change your shift points ... and what are your new shift points? Did you consider any upgrades to the trans unit to work with the new shift points?2001 Kroger\'s shopping cart<br />MODS-<br />* disabled locking wheel<br />* used Flowmaster and some LS1 parts ... I think there\'s an old Bilstein shock in there too.
