Does anyone know if anyone sells heads for the v6 3.8. if the do can you tell me how to get them and how much.
heads for 3800
The job would be time consuming, the main part though is putting everything back together, how much to torque bults, what silicone to use, that sort of thing, also gaskets and what not. You can run forced induction and NOS but you have to keep the compression down.
The best way to go is to get the heads and intake from Super Six and than get the cam from Comp Cams.1 of a kind<p>Red 97 Camaro<p>Modifications: <br />SLP CAI, RK Sport Headers, Car Sound High Flow Cat, 3\" piping<br />3\" Steel driveshaft, SFC\'s, Panhard Rod, MAC Torque Arm<br />Manual Fan Switch<p>Best E/T:<p>60\' 2.152<br />330 6.271<br />1/8th 9.704<br />MPH 71.93
Comp Cams grinds there cams from a core while Super Six simply re-grinds your used cam. So, you can get a much better cam with Comp Cams.1 of a kind<p>Red 97 Camaro<p>Modifications: <br />SLP CAI, RK Sport Headers, Car Sound High Flow Cat, 3\" piping<br />3\" Steel driveshaft, SFC\'s, Panhard Rod, MAC Torque Arm<br />Manual Fan Switch<p>Best E/T:<p>60\' 2.152<br />330 6.271<br />1/8th 9.704<br />MPH 71.93
