Im sending my heads of in a few weeks to get them ported and polished and a five angle valve job done. My question is should i get .550 double springs installed with 1.9 rockers?? The cam im getting to go with this package is going to have a pretty high lift on it so thats why I am doing this. And also will milling the heads take the compression up much higher or will getting JE to make me a custom set of high comp pistons be a better deal??
High compression!!!
Milling the heads will raise compression but you can only mill so much. If you want really high compression probly gonna be better to find another way. Like pistons. I milled my heads 20 thousands and it gained about .4 compression.
3800performance.com is working on .02 overbore pistons as we speak w/ compression ratio's of 9.5:1 and 8.5:1. high lift cam+1.9 rockers=bad. tell thee company that is making your cam about the 1.9 ratio rockers you plan on running and have them make the cam w/ that in mind. BTW, head/cam are much better in the long run than nitrous for the simple fact that you don't have to refill any bottles, and it's always providing hp/tq.
Don't mill the heads bc there will be piston slapping occuring if you do.
[ May 27, 2002: Message edited by: Patrick Javert ]</p>2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
<blockquote>quote:</font><hr>Originally posted by Bradley Palmer:
Piston slap is when a valve hits the piston right?? <hr></blockquote>
the term piston slap is generally referred to when the clearance between the piston and the upper portion of the cylinder wall has become excessive.
i think you're talking about piston/valve interference.ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
piston slap is when the piston is lose in the bore, and is striking the cilinder wall, its either a bad fit, or a busted piston skirt. This is a common cold start problem, with chevys, but goes away when the engine warms up. it has nothing to do with the head.Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
right, but he's also looking into increasing lift as well. a few tousnadth's here and there add up. I wouldn't be worried about piston/valve clearance until higher rpm's anyway, since that's when there's the most chance for valve float. also, the new pistons that 3800performance is making is 9.5:1 and 8.0:1, not 8.5:1. sorry about that. also, Bluecmro96, do you have the specs on where the piston sits at TDC, whether it's still in the cylinder, at zero deck, or out of the cylinder at all? I haven't been able to find the specs anywhere.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
I have posted some useful tech documents that could probably help you. You can find the here:
http://www.ditechllc.com/mitchell/2000/
The document that would probably help you is 3.8l.v6.pdf it has the engine specs.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
