Does a cam from a 98 3.8L fit a 97 3.8L? Also, how much HP would i get from putting in a cam with .320 intake lift, .325 exhaust lift, 206/216 duration at .050? Would it make it sound choppy at idle?
thats sounds like the vs cam by comp that i have. if so it also has a 115 lobe separation, the idle will sound good but not that choppy because its a nitrous cam, if na is what your looking for the a cam with more intake and less exhuast is what you want also like a 112 or 133 lsa. if need anymore info on my cam email at firefighter8615@aol.com
