ive bin hearing about hp tuner and just wondering what is? is a hypertec tuner couse i got one of thoughs but if not what is it? what gain well it give me on my 2000 camaro
what is a hp tuner?
what is a hp tuner?
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
it is tuning software that you install onto a computer (PC or laptop) ..then it uses a cable that runs from the computer to the diagnostic port in your car..there is a LOT you can do with it..so as far as gains..it depends what it is you are tuning for<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
oh ok well all i got is whisper lid, tb spacer, aluminum drive shaft, flowmaster muffler, and fast toys cai. so thats all i got for now. will the hp tuner do any better then my hypertec with these mods or just wait ontil i get bigger and better mods and just stick with the hypertec for now2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
probably just stick with the hypertech for now until you get more into modding with bigger bolt ons and such.
cool thanks for the 411 [img]graemlins/banana.gif[/img]2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
It will do more than a hypertech will even on a stock car IMHO.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
i will never again buy hpp...i can always add on whatever vehicle i buy onto hptuners for less then hpp can be bought for. Then again not being half bad at tuning doesnt hurt either ;)00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
the biggest advantages for me were recalibrating for my new gears, firming up shifts, being able to change my timing when running juice, making the car run a LOT cooler which was a problem for me due to the setup of the staging lanes here, and having the ability to recalibrate for bigger injectors if needed<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Originally posted by 96whitemaro:
will it work on a 96? and how much is it? thank you
Don't forget there is also DHP that offers a tuner at a much cheaper price. ;)Matt
1998 Mystic Teal Camaro M5
Originally posted by Chet Mo and the Camaro:
whats the diff. between dhp and hp tuners. i have stock 98 with exhaust.00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
