questions about msd - FirebirdV6.com/CamaroV6.com Message Board
questions about msd
  • questions about msd
    do you guys know anything about the MSD Stacker Single Channel Ignition For Engines With Distributors and if that will help out a 97 camaro with the 15 hp and the 20 ft lbs of torque? thx.
    2000 NBM M6 Camaro Z28<br />323/335
    I don't know if it'll give you that much power, unless you've already done a lot of bolt-on's and maybe heads/cam or forced induction. it'll get you better throttle response down low as well as allow you to fully utilize all of your bolt-on mods, long block, and forced induction.
    2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
      We don't have distributors.
      I am also a firm believer in our stock ignition. I tested the DIS-4 SEVERAL times.. back to back runs showed absolutely NO change.
      The DIS-4 is more of a 3.4 mod. They definately gain from it.
