They've talked a lot over on some v8 boards about destroking a 305 so that the bore stroke ratios are closer, and so the 305 can rev higher, producing higher horsepower numbers. I'm wondering if it's feasible to do with a 3.8L. back in the mid 1990's there was a 3.3L engine made, just a destroked 3.8L. Would a 3.3L crank and internals fit in the 3.8 block, then? i would imagine so...Perhaps that, a cam, forged internals, and like a 7500 or 8000 redline for higher horsepower out of our engines?
effects/possbility of 3.8 to 3.3L destroke
don't do it man! if you want to have a rev happy motor get that honka s2000. And weren't those motors fwd exclusively? they probobly had the cranks special for them too. The more power you make with having to rev the motor less will set you up w/a more reliable motor. Perhaps a better goal would be how to get your motor to rev quicker to it's yellow/red line than increasing it.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
I'd suggest aluminum heads because of their superior flow properties as well as the ability to raise compression a full point and still run on regular gas. this may be an even more reliable motor because the rod to stroke ratio is larger, meaning less angularity when pumping. Another good thing about destroking is that it lowers static compression while keeping the same pistons. This would work well w/ forced induction, especially since turbo's and centrifugal superchargers produce more boost at higher rpm's. The problem is, you couldn't get much out of the low end since we don't have vtec that kicks in around 3500-4000 rpm like Honda's do. just keep the crank the stock specs but get forged internals for them and run a 6500 redline, or maybe 7000 w/ aluminum heads.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
http://www.camarov6.com/cgi-bin/ulti...=6&t=005832&p=
can we get an ignore button, please? :rolleyes:2011 Camaro LS 6M, in black.
Umm... I'm just gonna say, don't do it. [img]smile.gif[/img]Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Reving higher is really killer on reliability. If I remember correctly (and I could be wrong about the number) engine component stress goes up as a cubed function to engine RPM.
So if you double your engine RPM, the component stress goes up by a factor of 8.
You're thinking correctly, just backwards. If you destroke an engine, you are effectively decreasing power for strength. If you increase RPMs to bring back power, you will have a heck of a time with efficiency. If you really want less stroke/more bore for RPM purposes, overbore your engine.\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
