how much can a 3.8 be bored - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    i also work with tiago in force fed fabrication jsut incase noone knew this.lol. if you are loking for an engine i could set you up with something. let me or tiago no if you wnat anything done and we will work something out for you.
    later
    \m/att
    boost, you got it???
    • #17
      i want to build my own engine but with help. dont want to just say "yup had someone build me an engine" i want to say "yup but her together with a little help. internals are easy. ill have the heads done and all but what should i do as far as compression? certain cam give me specs. thanks
      96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
      • #18
        How about this:
        L67 crank, rebalanced to 50%
        !balancer shaft
        3800 III connecting rods, modified
        9.5 L67 pistons or ZZP's custom 4.1 pistons
        ZZP GT2 cam 216/216 .507/.507 111ls
        aftermarket lifters, push rods, and valve springs
        Some Hogged out heads.
        SLP rockers
        P&P intake monifolds
        bigger injectors
        Then some major computer tuning.
        Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
        "I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre
        http://seppo.hopto.org/
        • #19
          plus a turbo right? will it handle that are those things forged? what compression should i go for a turbo anyway?
          • #20
            <blockquote>quote:</font><hr>Originally posted by mattsv6:
            later
            \m/att
            <hr></blockquote>
            i need help its called do you know anyone the can hook me up with dyno tune?!?!?!!?!?!?!?
            for the other asking about internals, go to my site in my sig, those are some of the best, with cost in mind, i have been researching priceing those for a year. i think matt and taigo will agree on that, (the heads are from them as is the turbo) i think Tiago is excited to see some number from me too. he also helped me with some questions i had. and begin in Iraq i had ALOT of qestions too
            matt please check my site, tell me what you think of my cam turbo grind?
            www.turbov6camaro.com
            1997 3800 Series II Camaro
            • #21
              so if you wanted to get the 4.1 stroker what computer tunning would need to be done? would the MAFT+ be able to do it or are the pre 98 guys screwed? thanks.
              white 1996 camaro 3800: flowmaster American thunder cat back. hypertech 160* stat, and manual fan switch
              • #22
                <blockquote>quote:</font><hr>Originally posted by white96six:
                so if you wanted to get the 4.1 stroker what computer tunning would need to be done? would the MAFT+ be able to do it or are the pre 98 guys screwed? thanks.<hr></blockquote>
                ok that i know of the computer has no clue what the c/r is, all it knows is the amount of air coming in and the rpms, then it takes that and adds the fuel it needs per amount of air. so if you get bigger injectors then yes you will need to tell the computer or is dumps to much fuel in. the O2 reading conferm the a/f ratio is right and is one more source to get it perfect.
                so if you stroke it your going to bring more air, IMO the comper will just hold the injectors open longer. to account for it.
                in my case i have to use the MAFT cause im goign to 42.5 lb/hour injectors
                • #23
                  ok but if you didi want bigger injectors like you are going with then the maft would fix that problem? thanks for explaining that.
                  • #24
                    Just to clarify, the old Buick 4.1 was/is the same block as the 3.8. The cylinder bores are siamesed, too. Same crank was used.
                    • #25
                      thats what I read, but the people in this forum that "know everything" said it wasn't. Maybe not the same series engine, but you know what I mean. Please guys if you don't know for sure, then at least say, "I think." Thanks.
