hi~ engine problem....quick answer..pz...... - FirebirdV6.com/CamaroV6.com Message Board
  • hi~ engine problem....quick answer..pz......
    hmm.. i rebuit my engine...so..
    i change everything of inside engine..
    piston, piston ring.. rods.. crankshaft..
    bearings...
    what is problem..is...
    when i pulled off supercharger from engine..
    engine was ok~just fine..
    but when i started engine with powerdyne supercharger...
    my engine's idling was not good...
    and i could feel that the air came out from dipstick hole
    when rpm was over up 4000rpm air with engine oil
    came out...
    so that is problem..
    whats wrong.?with my engine..
    please...quick answer...
    i should reduce my crank case's high pressure..
    1997 firebird convertable.<br />intense 8.5:1 forged piston,rods,slp1.8 rockerarm<br />255welbro,28injectors,MAF,CIA headers,magnaflow exhaust,intercooled powerdyne S/C,TAXAS racing ECU tuning,coni shock with spring,roll bar,etc~
    Time to rebuild that motor again.
    1997 Dodge Viper GTS
      If a noticable amount of air is coming out of your dipstick hole, you have serious blowby issues. It sounds like your piston rings are incorrectly installed.
      1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
        could be the pcv system, with a blower you end up blowing air into the crankcase unless you block it off the pressure will build and cause your dipstick to come out. Now if its blocked off then yea new motor but if you never blocked off the pcv system i bet thats the problem
          theres a hole in your throtle body, its the pcv system. it helps take air out of the crankcase normaly because there is a vacume in the intake manifold so it would normaly pull the air out into the throtle body where it would then go back into the engin to be burt up. you have to plug the hole and put a filter on your valve cover atleast. may need 2 air filters one on each valve cover if worse comes to worse.
          Your motor is fine dont listen to the people that jump to the conclusion that your engin is gone. ITS NOT.
            Drone is right. It's the PVC system, block it and use valve cover breathers to get the excess air out of the crankcase. The engine isn't the problem
            2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
              when i pulled off charger from engine,
              my engine was really.. quite and good idle and
              no~ air never comes out from dipstick hole..
              at that time i dynoed my car
              the horsepowwer was 169 at the wheel
              with magnaflowmuffler and 1.8ratio slp rockerarm
              i think pcv problem...
              hmm... can you explain how i shold do with
              pcv.... very easy way... [img]smile.gif[/img]
              im a korean so im not a good english speeker..
              i need easy engilsh..hehet~
              sorry...and.. thanks..for reply..
              im very apriciate...to you guys..
                take off your intake
                look in the throtle body
                see the hole
                it goes to the crank case
                if you dont the boosted air will go in the hole and into the crank case
                that is not good
                you need to plug that hole
                you can jb weld it close and then grind the excess off and make it smooth
                you will need a valve cover breather too once you do this
                  also talk to the couple guys with the rk sport supercharger on here they can help you and may have pictures
                    nice explain thanks.. drone..
                    timbo you too~ [img]smile.gif[/img]
                    i need pics... [img]smile.gif[/img]
