I bought a engine from a 00 camaro. I have a 99 firebird and i noticed that the injectors are different the pins and the diameter are different. What do i need to get to make these injectors work with my 99 wiring harness.
99 to 00 injector style ??
You have the opsosite problem that a lot of us have faced. We all went to an old style injector and had to put the Bosch style connector on our cars. You need to go from a Bosch style injector to a Multec 2 style connector. I think I saw the connectors on the internet somewhere but you will have to look.
Do a search on this site for "GTP Injectos" and you will see what it takes to change the plug type.
Do you have your old injectors? They might work just fine. I would try that first. It is a lot easier then putting on new connectors.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
send your old ones to CRUZINPERFORMANCE
to get cleaned & flow matached, etc. really good prices too.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
