now we can test out our techies..i dont get it!..SAME damn problem i was having with the nitrous before..im running a 120 dry shot (63 jet)..the fan nozzle is plugged into the air box so that it sprays down the tube into the intake..i purge..bottle pressure was about 850 psi (i JUST had it filled) ..it hits hard right when i inject it and feels really good..but then all the sudden its like the power just cuts out..and my air/fuel ratio gauge (i know..not reliable) goes totally rich..and then it just stays like that the rest of the run..between 5700 and 6000rpms my injectors(ms) were between 19 - 21..so id like to know if they're maxed out and im running rich..or if they'er maxed out and im running lean..i ran a 110 shot a LOT last season and it was perfectly fine..now the ONLY difference is im running the nozzle before the MAF..can someone read the A/F ratio and the rest of this file and tell me what the hell the problem is???
you may have to paste this in your browser...
http://mysickcamaro.50megs.com/test_run.cfg
i may have to email this file to you..PLEASE email me at doering18@yahoo.com
