hey guys i haven gotten my car back and i'm probably putting in the 24 lb injector tomorrow. what do you think i should be running. i have gotten so much input that i think that my head is going to roll off soon. sooo, check out the mods and let me know. i have a bin file on the way and the hp tuner to work with it. i was running so lean on the 22 lb injectors that they were white. help me asap i need to call them first thing in the morning if i decide to change the size yet again. HELP
what injector size
Hmmm... I run 19's...... but... I have stock cam.
You have a GT cam....22's didn't cut it?
Maybe accel 24's?Race car - gone but not forgotten - 1997 firebird V6
i got the 24 accel but my car just got the cam put in along with the p&p, gears posi and the 3 angle valve job. but just straigh off the back with just headers, y pipe high flow cat full exhaust ,cai, whisper lid and n/x. but i think that i have always been lean cause i would always fall flat on my face in a race once it came to second and third gear.(still won!) hehe always. i'm going to head up to the shop tonight to tune it and then hopefully pick it up tomorrow. wish me luck!
24s will be fine [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I don't know how everyone else feels, but with tuning out now I don't think going too big with injector sizing is a problem, it's better to get MORE than enough injector for your mods and your future mods than to get something that you're going to run lean on.
Even the years that need modifications to run GTP injectors I think thats the way to go, still cheaper than buying a new set.
and 36# injectors will support the majority of anything you would ever do. Also it would be easy to copy the injector tables from a GTP for the tune.
Thats just my opinion take it for what it's worth, but I don't see the point in upgrading to something as small as a 24# injector.
Thats just my opinion take it for what it's worth, but I don't see the point in upgrading to something as small as a 24# injector.00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
Originally posted by 1DangerousV6:
24s will be fine [img]smile.gif[/img]00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
is that due to his 4.10 gear ratio too??..i forgot she is using 3.73s in addition to the heads and cam..the nitrous wont have any impact because she is using a wet kit which doesnt utilize the injectors to pull more fuel<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
its due to alot of things, but mainly most cars gm puts out are on the ragged edge...does anyone know if ls1 injectors will swap over to the 3800? Like say stock ls1 28lb injectors?00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
I agree with the use of the GTP injectors. With tuning, I see no difference in drivability but I have plenty of room for the future.
As for the LS1 injectors, they have the same electrical connectors and they look identical to the GTP injectors. I think they would work just like the GTPs (2000+ would have to do some modifying) and you could cut and paste an LS1 table.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
yup..i just got my 36# GTP injectors in the mail yesterday :D<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I believe LS1 injectors are direct fit for later model V6s ie 98+
and LT1 injectors are direct fit for the earlier models.
Those years may not be 100% correct, but I know of some 24# LT1 injectors ran in 3800IIs and some 28.8 LS1 injectors as well.
As for the LS1 injectors, they have the same electrical connectors and they look identical to the GTP injectors. I think they would work just like the GTPs (2000+ would have to do some modifying) and you could cut and paste an LS1 table.00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
Originally posted by foff667:
what are the stock 22lb injectors rated at? It appears they are rated at 58psi like ls1 injectors...just want to make sure.
I agree that there is no reason not to put in GTP injectors now that we have software available. There shouldnt be any drivability issues using them. I have a set laying around ready to go in. [img]smile.gif[/img]92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
