Comp Xtreme 4X4 Cam, Plus Centerforce Dual Friction Clutch =
....and whats so good about this clutch?.......crickets....
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
Well, due to the fact that it didn't burn up, they are considering it to be a possible defect. They are going to make sure everything is OK and rebuild me a stronger disk (Stronger than the original dual friction disk). For under $75.
The clutch might not have the holding power of the spec 4 or 5, but it isn't supposed to. If their customer service wasn't so good, I would probably buy a spec.
1997 Dodge Viper GTS
hey does your car pass AZ emmisions with that cam? also how does it make your car run? do you do the work yourself or do you use a local shop? I am in AZ also so i am curiuos. thanks.
white 1996 camaro 3800: flowmaster American thunder cat back. hypertech 160* stat, and manual fan switch
I wouldn't dare use a shop. I did all the work myself.
Only thing needed to pass emissions is no SES light. It doesn't set one, but even if it did, I would reset it in the parking lot as it takes a few minutes to come on anyways.
[ January 20, 2004: Message edited by: AZ3.8Camaro ]</p>
a while ago i was thinking about getting it.. but could never find it. also, whats the price?
Update to this - they are putting the flywheel side on both sides of the new disk.
It should give it twice the strength of the original dual friction, and a little less longevity.
Oh well, when they explode, they don't last that long either....
Centerforce has been very cool about the whole thing, and they are replacing it and beefing it up free of charge.
BTW - even though it broke, I do not consider it a peice of crap. The clutch has never slipped and holds a 100 shot on nittos just fine. I believe it broke because of a defect. There where no hotspots on the pressure plate or anything. If you plan on using this clutch for a cam/100 shot nitrous and still being VERY streetable, it will work fine.
