LS1 tb on V6 (pic!) - FirebirdV6.com/CamaroV6.com Message Board
LS1 tb on V6 (pic!)
  • LS1 tb on V6 (pic!)
    Here is a link to my LS1 75mm tb to V6 plentum project.
    http://www.f-bodytech.com/forum/show...&threadid=2691
    What do you think?
    I dunno if there are differences in the LS1 I haven't looked in to it but on the LT1 the sensors are all the same, and the connectors so in my case I just plugged the wires into the Lt1 stuff.
      Look at the years of his car. This might not help the 3.8 guys
      2002 NBM Pontiac Firebird Formula<br />Mods: stock...<br />1997 Chevy Camaro *Gone*<br />Mods:Borla,headers,Magnaflow cat, SLP intake, NOS 5175
        also 99+ 3.8 have electric throtle bodys
        no wire for us
          Drive by wire &lt; me
          00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
            The sensor is different (tps) they don't look any thing alike.
            The LS1 and 2.8L tb bolt patterens aren't even close the 2.8 has 2 bolts spaced about 3'' apart the LS1 has 3 bolts the bottem 2 are about 2'' - 2.5'' apart and the 3rd hole is about 4.5'' above the center of the bottem 2 holes.
            The place where the IAC is, I just picked it because I saw that 2 holes all most lined up(from the 2.8 IAC houseing to the LS1), I could all most make the important part of the 2.8 IAC houseing fit on there.
            And that's what I did.
