I've heard lots about how our piston rings have a problem with blowby and pretty much suck. I'm getting a set of Ross Racing pistons and was wondering if the rings that they make for them (only one type i believe) are plenty sufficient to handle strong poweradders like 10-12 psi on a super or turbo or an 85-90 shot of nitrous. If not, I know Total Seal will make a set of plasma racing gapless rings for the pistons for near $230, just didnt think that would be necessary.
Piston Rings, Which Type to Get
C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail BirdsTags: None
gapless rings will make less power than regular type rings on an NA motor, i dont know the exact reason, dont know if anyone knows but they dont make as much power...im sure the rings Ross sells will be more than enough...
[ April 30, 2003: Message edited by: WickEdSix9838 ]</p><b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
If you guys do some research on gapless rings, you will probably find that there is a problem with oil consumption. I called Total Seal about this because I wanted a set in my 3.4, especially with the amount of nitrous that I am running.
Usually, when you refinish the cylinder walls, you use a 600 grit stone for the final finish. With the Total Seal Gapless rings, use a 220 grit at a 45* crosshatch. They said that this will eliminate the oil comsumption problem.
With the Total Seal kit, at least for the 3.4s, the top ring is a plasma moly ring and the 2nd ring is a gapless ring.
This is the best set out for performance in MOST situations. Be prepared to pay the high performance price though.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
