I've heard lots about how our piston rings have a problem with blowby and pretty much suck. I'm getting a set of Ross Racing pistons and was wondering if the rings that they make for them (only one type i believe) are plenty sufficient to handle strong poweradders like 10-12 psi on a super or turbo or an 85-90 shot of nitrous. If not, I know Total Seal will make a set of plasma racing gapless rings for the pistons for near $230, just didnt think that would be necessary.
Piston Rings, Which Type to Get
C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail BirdsTags: None
gapless rings will make less power than regular type rings on an NA motor, i dont know the exact reason, dont know if anyone knows but they dont make as much power...im sure the rings Ross sells will be more than enough...
[ April 30, 2003: Message edited by: WickEdSix9838 ]</p><b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
If you guys do some research on gapless rings, you will probably find that there is a problem with oil consumption. I called Total Seal about this because I wanted a set in my 3.4, especially with the amount of nitrous that I am running.
Usually, when you refinish the cylinder walls, you use a 600 grit stone for the final finish. With the Total Seal Gapless rings, use a 220 grit at a 45* crosshatch. They said that this will eliminate the oil comsumption problem.
With the Total Seal kit, at least for the 3.4s, the top ring is a plasma moly ring and the 2nd ring is a gapless ring.
This is the best set out for performance in MOST situations. Be prepared to pay the high performance price though.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 day ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...3 days ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....1 week ago
