How hard woudl it be to move the motor 6 in... It woudl still give room for the stock 5-speed shifter, I know a custom drivesahft woudl be neccesary... But the motormounts, tranny mount and crossmembers... how hard would it be to do?
How hard would it be to move the motor forward about 6 in...
I could see fuel lines being replaced do you think you would have to extend the wiring harness? Its only 6 in.
I know you woudl also have to cut a bigger hoel for the shifter.
Its 6 in. not really that far...
Its jsut thoughts of the firwall/M90 blower problem [img]smile.gif[/img] height I doubt will be a problem, from some mini measurements Itook last night at the track.
ah hah
what about steering linkage? honestly, for all the stuff that i've thought of, it wouldn't be THAT bad if you had a month and some fab-ability. as far as the wiring harnesses, i suppose you'd also have to switch computers so it wouldn't be a huge deal.
that blower would be vicious... i've always wanted to do the swap. [img]graemlins/thumbsup.gif[/img]
<blockquote>quote:</font><hr>Originally posted by RallyRed 98:
ah hah
that blower would be vicious... i've always wanted to do the swap. [img]graemlins/thumbsup.gif[/img] <hr></blockquote>
steering linkage... think you could jsut shorten it just a little?
I doubt I will do it, I am not a rich man... but looking into it... for others. Figure look at it from a different point of view, instead of cutting the firewall away [img]smile.gif[/img]
another problem is the hood, I say cut a hole and let the blower stick out Mad MAX style :metal:
Eric I'd say the biggest issue would be the steering rack in it's entirety. Everything else is a matter of lines / wires (fuel, brake, alternator, harness, A/C), but the steering rack is a large mofo that bolts to the K-member. (Trust me, I know, I just went tubular). It's the one thing that has to stay relatively close to it's orginial position, even if you can modify the steering linkage (snag an Unbalanced Engr !ragjoint while you're at it).
IIRC, at lexus the IS300's steering rack is on the backside of the K-member. And it's just lines to a PS pump -- no trouble there. So if you move the entire Engine forward (new pan, unless you go really far forward), run some adapter plates back to the K-member mount holes, and then mount the steering rack, you'll be OK.
Another Idea would be to have BMR / etc custom make a K member for you that has stock suspension / chassis pickup points, but motormounts that are 6 inches or whatever forward. And then weld up some mounts for the rack yourself.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
why in teh world would you want to move an engine forward?
for weight distribution it would be a terrible thing for the car, even if only moved a few inches, much less 6. the performance benefit would be negative for drag and handling performance.
you can do it with a few home made brackets, prolly, but i can't imagine why you would want to.
later
timNJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
by the way.. in engineering and fabrication terms... 6in is NOT a little bit....00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
Go to the Eaton website, they make blowers w/tb facing forward & off to the side. http://www.magnusonproducts.com/pdf/catalog.pdf1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
3rd gens have THIS MUCH ROOM to begin with. Yeah, it's nice seeing the whole freakin engine :D ;)1978 Formula 461 in progress of being built :rock:
94 comero 3.4
MAN! it must me SO EASY to work on your car!!!!96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
