dude you have to post some sound clips of that thing when you are done! Good luck with the troubleshooting and tuning.....let us know how it goes
Do I need tuning or is something just bad?
well i thought maybe the valves were adjusted wrong so last night i tore the plenum and fuel rail off and opened up the valve covers.
my comp install guide says to rotate the engine until the intake valve opens and closes then adjust the exhaust rocker. then rotate the engine until the exhuast valve begins to open, then adjust the intake rocker. they says you tighten the rocker nut until the pushrod wont spin in your fingers anymore.
anyway i backed the nut off and readjusted them and went for a drive this morning. i notice a slight bit more pull and the top end seems a bit better, but honestly i dont know what im doing with this rocker adjustment thing. some people tell me to adjust the rockers until the pushrod stops wiggling, some say do it til it stops turning.
so is it possible theyre adjusted wrong? what would the engine be doing if the rockers were too tight? too loose?<b>1995 Bright Red 3.4L</b> <br /><a href=\"http://www.cardomain.com/id/94camaroguy\" target=\"_blank\">Carmen\'s Page</a>
run like shyt
wont start. lots of things. can happen if not adjusted right.
if i didnt have my distributor 180 off when i tried to fire mine up. the next thing to do would be to check, and fix every valve. in adjusting them all. what a pain in the @$$ that woulda been.
now its waiting in the dealership on a lift for the fuel line to come in to replace whats htere its rusted i dotn want it ther ecant get the filter off. and need to chang eht efuel filter.
and im waiting on the alignment/windows to be fixed. and then its off to the exhaust shop to spend 300-400 on a custom x pipe system. to my glass packs.
btw i have a distributor. i have an old school 350 sbc carbed in my 4th gen. v6 fbody.<a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
i have a carbed sbc 350. with a th 350 in my fourth gen. btw a 3.4L has a distributor hole in the intake manifold. just an FYI.<a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
i never said 9it has a distributor. my 5.7 350 gen 1 block has a distributor.
my 3.4 Does not. which is in the scrap heap up at bob sellers pontiac.
ill hopefully have it on the road monday or tuesday. all depends on the weather to get it trailered down to the exhaust shop then how long it takes them. and teh weather to trailer it back.<a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
