I now have a Custom Grind Cam from comp cams- 76-000-9 206/212 .320/.325 114 and will be purchasing SSM heads within this week. I have the mods listed in my profile. I do believe that I will be needing a Spec Stage 3 clutch, one piece driveshaft and lsd. Now on to the other mods like maft+ ect... Should I buy a custom tunned PCM and Maft+ or just the Maft+?
Also what kind of time and number could I possibly put down with these mods including the 100hp shot?
What are your stock times? I would think if you add everything you mentioned you should be in the 13's with a 100 shot. 14's without it
2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
