clarification - FirebirdV6.com/CamaroV6.com Message Board
clarification
  • clarification
    to me this is advanced, but feel free to move it.
    anyway, i need some clarification from this link
    http://www.tacreationsusa.com/3_4_3_8_v6_to_ls1.htm
    mainly,
    LS1 steering rack/ does having y87 take care of this?
    LS1 throttle cable - The LS1 throttle cable is mounted on the RH side of the throttle, and also sits forward more than any other motor. 99-02 V6 owners will require a mechanical throttle gas pedal, as all the 99-02 V6 throttles are operated by the computer.- i need a lot of help with this one [img]graemlins/dunce.gif[/img]
    LS1 gauge cluster/ just a new overlay or the whole piece?
    A/C condenser, accumulator and evaporator - [For 97 and older models only] The condenser is only a mandatory change since the ends are different. You can avoid changing the condenser if you have your hose ends altered. The accumulator and evaporator ends are also different, but can be avoided with a modified hose.
    Harnesses - Every harness is different in the car : Underhood relay harness, dash harness, door harness, engine harness, etc ---does every harness have to be changed? or just the engine?
    i realize now that its almost everything on the page, thanks
    - \"So you have something to look at when you\'re talking to \'em\" - <br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=296916\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=296916</a>
