i use to run the maft+ onm y stock ignition. i'll look for the wire again.. i'll shoot you an email today.
Timing retard - what works? (trc-1 no longer available...)
Here is a link to the instructions for installing the maft+ that Mike sent me the wire info should be in there!
http://www.migpc.com/Modifications/M...ody_maft_.html
John, I've been out of town for the last few days, just sent a reply to your email before I found this post.
Somebody else on the board, I think it was slacker tried the TRC unit and it did not work. I'm using the boost retard feature hooked up to a MAP sensor. It's retarding the timing using the same wire from the PCM to the ICM that the MAFT+ uses. The link I had to the 98 pinouts is dead but I know they are different from the 99 so make sure you are looking at the correct pinout sheet.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
I believe it is the white wire. That's the one called ignition control. The other candidates are 3x and 18x references... Probably not those.
The white wire was mentioned in the link a couple posts up too. It was for a gtp I believe, but the icm layout is probably the same.
I'm going to give the trc-1 a try, since I already special ordered it. (it was half the price of the maft+...)
When I wire it, I'll tie it into my nos relay, so it only comes on when I'm spraying.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
The local speed shop came back and said their sales rep explained that the TRC-1 is no longer available...
Any other units besides the MAFT+ that can retard timing? (for less than $300....)\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
<blockquote>quote:</font><hr>Originally posted by John_D.:
As long as the engine holds up I will... :D
I'm thinking about a second stage, another 50 shot, from 4500-6000 rpms only. (which is right at 90%+ of the 2nd and 3rd gear range at the track...)
Gotta get the kr resolved first though.
I am going to join the 12's club very soon. [img]smile.gif[/img] <hr></blockquote>
Just my opinon:
If you're gonna be doing it up like this, go ahead and get the MSD DIS-4 and the Jacobs Nitrous Mastermind.
You're in the realm of the BIG BOYS on this board now. In fact, you are one of the BIG BOYS. Money you've spent, and are going to spend on your car is no longer relavent. You're an innovator now. :D
Do the sh*t right, or run a 100 shot like everyone else.
[ May 26, 2003: Message edited by: AMinor65 ]</p><b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
