my intense stage 1 cam specs - FirebirdV6.com/CamaroV6.com Message Board
  • my intense stage 1 cam specs
    well it looks like scott decided to post the "secret" cam specs. I already have one that i'll be installing soon but just for anyone else thinking about getting a cam and checking out different specs here ya go.
    The Stage 1 Cam is perfect for use with stock heads, lifters, rocker arms, springs, retainers, and pushrods. You can use 1.75:1 rockers for additional lift on the exhaust side if you are using stock heads, or you can use even higher rocker arm ratios with modified cylinder heads. The powerband is strong from 3,200 to 6,500 RPM, so you will want to use a higher stall torque converter, such as our INTENSE™ 245 mm. Extreme Duty Torque Converters.
    CAM-361 - INTENSE™ Stage 1 Normally Aspirated Cam, duration @ .050": 212º/204º, lobe lifts: .322"/.298", valve lifts with 1.60:1 rocker arms: .515"/.477", lobe separation angle: 113º, intake centerline: 109º
    i was swimming in the carribean. animals were hiding behind the rocks except for the little fish, but they told me the squid\'s trying to talk to me. oink, oink. where is my mind?
    Is there a reason to favor the intake in both duration and lift by that much?
    Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
      So any before and after Dyno runs for this? That's really what we need to start getting. I wish I had gotten that for mine but just now there is a dyno here which isn't open to the public yet.
      1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
        Wow reverse split. That'll be interesting to see what kind of results you get.
        http://seppo.hopto.org/
          I believe thats the shottiest sounding cam I've ever seen for a 3800-II. If it does well I will be very impressed, because the way our heads flow and all... that is a terrible cam. :eek:
          2002 5-spd NBM Camaro
          Details: www.1lev6.com
            that's why they came out with a stage 2. i hear the stage 2 is sick. something like a 220/224 :eek:
              it may not look good on desktop dyno, but it looks pretty good breakin the grand prix's NA record. then the guy Wes put in the stage 2 cam and stage 1 heads and broke his own record and is currently running a 13.9. i think he got a 14.4XX with just the stage 1 cam and you have to figure it'll probably work out better on a rwd car that can get better launches. we'll see if i ever get some money to get all the stuff i need to make the swap. unemployment don't pay so much.
