which cam kit should I get - FirebirdV6.com/CamaroV6.com Message Board
  • which cam kit should I get
    theres is 3 kits available at FTPP site and I was wondering which would be best? and which cam with it? if I would get the complete kit how much hp could I expect?
    COMP-K-KIT-3.4LV6
    Comp Cams K-Kit (Complete Kit)
    1993-1995 3.4L V6
    Please Select Camshaft (See Specs Below)
    $293.20
    Camshaft Number:
    COMP-16.115.4COMP-16.232.4COMP-16.233.4
    COMP-SK-KIT-3.4LV6
    Comp Cams SK-Kit (Small Kit)
    1993-1995 3.4L V6
    $218.41
    Camshaft Number:
    COMP-CL-KIT-3.4LV6
    Comp Cams CL-Kit (Cam & Lifter Kit)
    1993-1995 3.4L V6
    Unless I knew exactly what parts come with those kits, I wouldn't get any of them. For example, how stiff are the valvesprings it comes with? Which lifters?
    And you can't just chose a cam based on how much hp it will give you. There's been a few threads about 3.4 cams lately, I'd try reading through those to get an idea.
    Matt
    1998 Mystic Teal Camaro M5
