Getting my walbro installed today. I have read all the posts I could find about it and just want to make sure 100%!
I have the Camaro 5.7L 1994-2002 255 LPH *pump#GSS307 from http://www.jdsperformance.com
This being the correct pump, I read that it is ok to ditch the plastic housing entirely and clamp the pump to the fuel arm?
This is the information I told the shop installing it but wanted to make sure there are no other real complications he should have installing it once he gets rid of the plastic housing because he is doing it right now!
There were 3 lines going into the plastic housing will all those hook up just fine without the housing? (feed line, return fuel line, vapor line is that correct?)
