What is the stock spring install height for the 3.4 heads? I need to know what i need to do to get the K-motion K-700 springs to work (locks retainers etc.)
Spring install height
MODS:<br />3.4,Crower cam, K-motion valvesprings, Heddman Longtubes, BBK AFPR, Accel Coil, 36mm/23mm Sways, Boxed LCAs/Panhard bar, Mutant Nitrous wet kit, Mr. Gasket Cutout, 10.02 1/8 mile at 67.2 mph UNTUNNED no sprayTags: None
They will work at any installed hight.
On 3.4 heads they installed hight is around 1.7'' so you should be able to put them on there and go.
What cam are you useing?
You might want to shim them some so you ge them closer to there open high so you can get the full pressue of the springs.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
Crower Baja Beast (.442I .444E 204*214*). There's athread over at thirdgen, why didn't you say somting there :( . Oh well, I'm going to go ahead and get the .050 over valve locks from Crane. [img]smile.gif[/img]MODS:<br />3.4,Crower cam, K-motion valvesprings, Heddman Longtubes, BBK AFPR, Accel Coil, 36mm/23mm Sways, Boxed LCAs/Panhard bar, Mutant Nitrous wet kit, Mr. Gasket Cutout, 10.02 1/8 mile at 67.2 mph UNTUNNED no spray
