Resistor in the Coolant temp Sensor - FirebirdV6.com/CamaroV6.com Message Board
  • Resistor in the Coolant temp Sensor
    I am plannign on running an LT1 tb on my new setup, but i don't have that plate that attatches to the bottom of the throttle body, which the coolant sensor connects to (under the TB, not the TPS) if i have it blocked off completely, can i just throw a resistor in the sensor, or do i have to buy that plate from ta creations for $40. because essentially, it makes no sense to me to worry about a sensor that leads to nothing. i am running a coolant bypass neway. If so, what ohm resistor should work?
