Porting cylinder heads - FirebirdV6.com/CamaroV6.com Message Board
  • Porting cylinder heads
    What are the pros and cons of doing this?
    Pros = more power.... cons = kinda expensive if you aren't doing it yourself.
      pros: more power/torque, broader powerband, higher detonation threshold/less chance of detonation
      cons: time consuming process, cost, quality of port job
        The cons are getting it done.
          Dose anybody have an rough idea on the hp and torque gains at the rear
            probably not too substantial on a stock car...but they will help out alot more on a heavily modified car
            1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
              So basicaly a waste of time and money at this point.
                If you put a cam in with ported heads you will not have wasted you time.
                  i picked up about 60-70hp from porting my heads, a cam, and LT headers, its WAY worth the time and money....
                  <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
                    Ok then I still have some much needded mods to do first then I will take it into consideration.
