new 3.4 motor help - FirebirdV6.com/CamaroV6.com Message Board
new 3.4 motor help
  • new 3.4 motor help
    ok well i started it up today it runs rough wont stay running unless i give it gas doesnt idle just cuts off umm i was wondering if it could be because of bad coils or if it like needs time for the computer to accept everything helppppp i have a 3.4
    1995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
    pvc system could be lacking air is the upper and lower intake bolted down correctly?
    have you checked for suction?
    are all the spark plug wires on the right way?
    just an idea.
    ---Niño---<br /><i>95\' silver 5 spd</i>
      Check the wires, check for fuel. If the wires are in correctly, and you are getting fuel, I would next Make sure the MAP sens. is connected, alond with O2 sensors and Camshaft sensor. Unless the motor has a mechanical problem (internal engine) it's an electrical problem.
      MODS:<br />3.4,Crower cam, K-motion valvesprings, Heddman Longtubes, BBK AFPR, Accel Coil, 36mm/23mm Sways, Boxed LCAs/Panhard bar, Mutant Nitrous wet kit, Mr. Gasket Cutout, 10.02 1/8 mile at 67.2 mph UNTUNNED no spray
        its a new motor i think its the injectors thats pretty much the only thing thats not new on it
          Check vacuum, and then if you have an air/fuel gauge handy, that would also help lots. Good luck though. [img]smile.gif[/img]
          Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
            just an idea.
            Thats 2 that say to check the pvc make sure you have working properly. [img]smile.gif[/img]
              Sounds like a vacuum leak to me.
                well i was lookin at the lines i didnt find anything unconected but there this one line that goes in the wiring harness in the back where does that go
