my bird has 56k miles on it. when i hit the gas a lil bit of smoke comes out but not a whole lot. it does it like once or twice then thats it. i use mobil 1 but i was wonderin if royal purple would work better? i thought the m1 would be more than good enough. could this be the piston rings that are messed up. i cant afford any thing like this or risk a new engine when i go to the track. any advice would help.
a lil bit of smokin
Is the smoke blue or black? Blue is oil and black is fuel. If it is blue, you may be blowing a little oil past the piston rings. Does it only do it for a few minutes when you start the car when it is cold? If so, it possibly could be oil leaking through your valve seats and sitting in the cylinder until you go out and start the car and then it burns it. I would start by doing a compression check on all cylinders first. Get a Haynes manual and follow the instructions for a compression test. It will tell you what may be wrong based on cylinder compression.
not really advanced but...
my car smokes a little bit when i first start it up...i dont really worry about it just make sure to check your oil1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...19 hours ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....5 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.5 days ago
