Those of you who have rebuilt a 3.4 liter. is there a performance rebuild kit out there and if so where did you find it??
3.4 LITER REBUILD
<blockquote>quote:</font><hr>Originally posted by v-6komodo:
wimpy emmissions cam???is their replacement just a regrind??<hr></blockquote>
I honestly don't know, I just know that it is a dinky cam for emmisions, but a few guys have gone with the non emmisions crane cams and got a lot more out of the car.Black 96 Z/28, A4, T-tops, tint, 2.73 LSD, Kenwood.<br /><br />Previous Camaro: Bright white 86 Camaro, MPI 2.8 A4 3.42, tint, Z-28 wheels, a few goodies.
Drop me a line and let me know how far into the 3.4L V6 you want to go. I will put something together for you if you like.
** Stay away from shelf cams for the 3.4L V6. Go with a custom grind based on flow numbers from your heads...you will get better performance this way.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Viper
I need to do a whole engine rebuild because the engine has 101k miles on it...all the info I have come across tells me to do a whole engine cuz a top rebuild alone will jack my engine up...as far as the cam goes i still want to use my car for a daily driver plus I have emmisions here in TN to deal with.
Rebuilding the top end will NOT jack your engine up. Rebuilding your bottom end will be pricey and extensive. If you want to do it, I will be happy to help. If you just want to do the top end, that would be a lot easier on you and on your pocketbook.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
v6-komodo raises a good question, does anyone make .030 over pistons and rings for the 3.4?
Josh-\'94 Camaro A4<br />Mods: K&N Conical, Dynomax Muffler, Dynomax 2.5\" I-Pipe, Jetchip Stage II, 180 Stat, RKSport Underdrive Pullies, Fan Relay Switch, Rapidfire Plugs, Bosch O2s, Goodyear GA, Aluminum Driveshaft, Alpine CD... <p>And also: Ported and Polished Plenum, Ported and Polished Intake Manifold, Ported and Polished Heads, 5 angle valve job, Raised Compreshion, Tranny Cooler, 19lb injectors, no new times yet.<p>\'95 Dodge Stealth M5<br />stock as a rock...
i have a gasket set i can sell yea along with some ported and polish heads and intakes all matched with a valve job for cheap considering i have no use for them i also have a custom grind cam for sale but it's prob to big for you. all this is brand new1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
