any 3.4 guys interested in heads/cam? - FirebirdV6.com/CamaroV6.com Message Board
  • any 3.4 guys interested in heads/cam?
    Well, as most of you know.. most of you good people.... Supersix is one of those companies out there trying to HELP us. Tom@Supersix specializes in V6 peroformance. He's not some LS1 V8 company trying to get a little $$$ by doing V6 stuff, V6 stuff is what he does. He knows his stuff.
    Check out this:
    http://www.supersixmotorsports.com/f...le=Engine+Tech
    He's looking for 3.4 feedback.
    Also, for any others looking into P&P heads and cam advice, I highly recomend you give tom and e-mail. He really knows his stuff and his work is top notch.
    The more GM 3.8 work we can give him, the better his knowledge of the GM 3.8 will be.. and perhaps he will produce even better flowing heads than he already is.
    Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
    He's got my input now :D
    Steve
    FirebirdV6.com/CamaroV6.com Administrator
    Stupid is rewarded with the ban button.
    Official Avatar Nazi according to Meatyshells :D
      left mine too. whe you think about the 2.8/3.1 peeps, Super Six isn't just for 3.4s anymore ;) [img]graemlins/thumbsup.gif[/img]
      2013 Ram 1500 Big Horn
      94 comero 3.4
        I couldn't wait for an engine specific shop to start doing 3.4 stuff so I decided to get it done by a local shop. Just got it all broken in and the results are amazing. Can't wait to hit the track again with some work done to the car. If Tom can get someone's 3.4 to do better, however, I just might have to switch up.
        Josh-
        \'94 Camaro A4<br />Mods: K&N Conical, Dynomax Muffler, Dynomax 2.5\" I-Pipe, Jetchip Stage II, 180 Stat, RKSport Underdrive Pullies, Fan Relay Switch, Rapidfire Plugs, Bosch O2s, Goodyear GA, Aluminum Driveshaft, Alpine CD... <p>And also: Ported and Polished Plenum, Ported and Polished Intake Manifold, Ported and Polished Heads, 5 angle valve job, Raised Compreshion, Tranny Cooler, 19lb injectors, no new times yet.<p>\'95 Dodge Stealth M5<br />stock as a rock...
