i have a 3.8L 97 and saw the video of slacker69's cam (210/220 .535/.547 113 ) and am wondering what the numbers mean and what is involved in a cam swap with this particular cam, such as what else needs to be changed. Im new to the cam and if i cant do it myself how much would a cam swap cost?
slacker69's cam?
Search this forum...there are hundereds of other topics that talk about this. It is quite labor intensive and if you can't do it it would cost around $600 for the install if you are lucky.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
I would not put that cam in unless I upgraded the entire valvetrain. also, that much lift needs ported heads. i'd get my entire drivetrain from intense racing, except the cam. get that cam, get the oil-restricted lifters, lightweight pushrods, stick w/ the stock ratio rockers, titanium retainers, high lift valvesprings, and stage 3 cylinder heads.2001 Arctic White Firebird<br />More mods than I\'m allowed to list!
Sup man my cam is really strong but there are alot of things you need to buy with the cam like a full gasket set and New high lift Springs and Retainers and Pushrods. As well as some head work like some port and polishing and valve job. I did mine myself. So i cut that cost. Install is a pain i would not attempt it if you have never done anything like that. It took me 2 Days. If you have any questions you can IM me at Crappyday21
[ May 18, 2003: Message edited by: slacker69 ]</p><b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...6 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 weeks ago
