i have taken my heads off and found some rust on one of the head valves its just a little spot but the engine has 125,000 miles on.... know im wondering is it the head gasket blown or is there a crack in the head i really would rather buy a head gasket than have the head pressure tested help if any one know also could this maybe from a crack in the block
its on the intake part the one that goes to the cyliners with the big holes i only found a little rust on one of them at the front of the motor i know i need new head gaskets for the rebuild but what im wondering is was it a leaking head or head gasket that caused the rust
also another ? what a good price for a 3 angle vale job
ok man this is it i had a bearing spin which i belive is from coolant getting into the oil....with me when i broke down the block i found that thier was rust on the cylinder wall and on the intake part of the head which means 1 of 2 things the head gasket was leaking and it let coolant in and that whats the rust si from or the head is leaking and that caused the rust thats the best i can explain it so let me know if you understand
