am i running too rich or too lean? i don't know how to really read the o2 mv values--any insight appreciated...also some o2 mv explaining would be awesome [img]smile.gif[/img]
According to the manual, the typical values are from 100 (lean) to 900 (rich). Based on that, it looks like you're running rich. However, I don't know how that voltage corresponds to the actual A/F ratio.
yeh, i get the P0300 code...i don't put too much trust into the misfire count honestly...seems atap is all over the board when it comes to that...like sometimes i'll get a 15000 or 800 etc etc misfires in one frame. ((shrugs)) also the atap a/f ratio always shows 14.7:1 no matter what so of course i don't trust that either.
ok i will have to hit up the dyno then.
for max power what should i be looking for for a/f ratio? is 13:1 good? thanks..
