smoking. . too much fuel? - FirebirdV6.com/CamaroV6.com Message Board
  • smoking. . too much fuel?
    The car smokes constantly (white smoke)hot and cold. I don't believe it's a head gasket. I don't see any leaks, and there is no oil in the coolant or vice versa. The plugs are covered with carbon after running for a little while, and smell like unburnt fuel. It only throws codes for misfires, after the plugs are covered with carbon.
    I recently removed the supercharger that was on the car after it helped destroy my clutch and tranny. I've tried reseting the pcm and still have the same problem. The injectors are stock. I am assuming it is still trying to dump enough fuel in there for the supercharger. .when resetting the pcm does it take it back to "factory type settings"?
    If anyone has any ideas please feel free to send them. Thanks
    6 days ago
