If it is indeed slower than before, you likely messed something up on the install, ie: didn't line it up dot-to-dot, etc. Secondly, who gives a rat's behind what a Gtech says, really? Those things are wrthless, baselines or not. Go to the track, get on a dyno, or just use the SOTP dyno. But don't go off what a Gtech says. If you weren't on the same road, heading the same direction, starting at the same place, those things will always be inaccurate at best, and even then they suck.
Moral of the story: check into the rest of the story before persuading someone agasist the cam or intake...there's probably something else going on.
