HEADS/CAM DYNO RESULTS! - FirebirdV6.com/CamaroV6.com Message Board
  • HEADS/CAM DYNO RESULTS!
    Had my car dyno'd today.
    193HP
    213TQ
    at the wheels.
    My car has issues. I need autotap.
    So I take it you are dissappointed?
    <a href=\"http://www.geocities.com/anoxie00bird\" target=\"_blank\">My car</a>
      What was your before dyno? Gains? What kind of issues, put them up, I'm sure you can get some help.
      Tom
        Im not so much dissapointed. But im not happy. My car has what I believe to be an injector TICKING really loud. I think its going out. It also has a small leak on the header collector.
        I forgot to mention. They said they had trouble getting a strong signal from my tach wire. Soon as I hit about 5200RPM the signal falls off bad. So I am thinking with the engine if I am PEAK HP higher than 5300RPM it did not show on the dyno. I will scan the dyno slip and show you what im talking about.
        I am also throwing codes saying my O2 sensors are bad. I cant figure out why.
        P151
        P131
        I need help.
          yikes :( even with those problems you would think you would have better results man thats alot of money for such little power gains from ssm :(
          Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
            <blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
            yikes :( even with those problems you would think you would have better results man thats alot of money for such little power gains from ssm :( <hr></blockquote>
            The car has more power than this. On the dyno they said they were loosing a tach signal from my plug wire above 5200 RPM. So the dyno only went to 5200RPM. I would like to think by the way my car feels it peaks HP closer to 6k. I am going to get a few things fixed and try a different dyno.
              Hmmmm,that's a nice 40hp gain over what I've seen stock 3.8's dynoing but what happened to the torque?By the way,it would REALLY help if you had dynoed the car stock for comparison.Good luck getting everything straightened out.
              Kevin
              1998 Black Z28<br />1995 Black 3.4 (@#$$%* ex took it!)<br /><a href=\"http://photos.yahoo.com/bc/nikkev1/lst?.dir=/New+Camaro&.view=t\" target=\"_blank\">Pics</a><br /><a href=\"http://www.scfyb.com/phpBB2/\" target=\"_blank\">Carolina Board</a>
                I have the dyno graph scanned to my computer. I can show you guys but I have no place to host it.
                Who can host this for me?
                  http://chevmaro.tripod.com/dyno1.bmp
                    I'd be very disappointed with those results. Doesn't make a strong case for SSM heads to me at ALL. I'd just assume leave my stock heads alone with a monster cam.
                    Scott
                      i second idea that scott.
                      <blockquote>quote:</font><hr>40hp gain over what I've seen stock <hr></blockquote>
                      wow dude, that's sucky; if you have a 3.8 that dynos 153 hp STOCK, your car has SERIOUS issues.
                      <blockquote>quote:</font><hr>My car has what I believe to be an injector TICKING really loud <hr></blockquote>
                      wrong. our injectors are supposed to tick. the louder the tick, the better shape they are in. if they aren't ticking your car has issues.
                      [ October 06, 2002: Message edited by: Only4U ]</p>
                      2000 NBM M6 Camaro Z28<br />323/335
                        :( 30 more HP than me
                        ;) I'll take your car
                        ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
                          Listen to what I said. The car peaks HP close to 6k. The dyno only went to 5200RPM. I know it aint the greatest results but its a small cam. I wasnt expecting much and i am happy with it. Peak HP is higher im sure of it.
                          My injector ticks extra loud. I know it aint supposed to sound like this. I also have 2 bad O2 sensors.
                            P I vouge for yea...I can feel the power increase...Lets just get those few things work out and then get it dynoyed again...And log into IM...
                            \"If I have seen further, it is by standing upon the <br />shoulders of giants.\" (Isaac Newton)
                              I don't have alot of experience with dynos but I know that an 800RPM difference can possibly be 10-15hp difference especailly with heads cam that like to rev higher than stock at your peak HP...just my opinion though!
                              1999 Black Trans Am A4<br /> <br />-Flowmaster with Flowtech Cutout <br />-SLP Lid <br />-SLP MAF <br />-Ported Heads, hardened pushrods<br />-Diable Sport Programming<br />-18\' ZO6 Polished rims
