I was having really bad KR after the Heads and Cam and 3800 stall. Then i remembered seppo writeing up something about having the same problem and he fixed it with resistors well. I did it this weekend i put some 100K 1/2 Watt ressitors inline from the cm with the KR Sensors and what do u know my 12-14.9 degrees of KR is now gone and feels like i gain 50 hp. I wish there were more mods for only .99c that can give the gain i felt from doing this.
[ May 26, 2003: Message edited by: slacker69 ]</p>
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
"I was having really bad KR after the Heads and Cam and 3800 stall. Then i remembered seppo writing up something about having the same problem and he fixed it with resistors, so i decided to try it this weekend. i put some 100K 1/2 Watt resitors inline from the pcm to the KR Sensors, and my 12-14.9 degrees of KR is now gone and feels like i gain 50 hp. I wish there were more mods for only $.99 that can give the gain i felt from doing this."
thnakss rosss c i appreciate the translation. stay ind schioodl overyone
Will your KR sensor still sense?
Meaning that if you do get ping or knock or whatever, will you get some retard?
Your sig is the most important part of your message. Make sure that you list EVERY single thing that you have done to your car so that we can all go \'oooh!\' and \'Ah!\'. Please make your sig consistently longer than anything else you post. Please include your lengthy sig with EVERY single post you make during a reply, even if you only reply with a monosyllable grunt.
my knock is false it is knocking in the computer without real knock. They are over sensitive so i desensitzed them like a condom
