ok i know nothing about cams but anyways. i was just wondering what kind of cam i should get for my 3.4L and what specs? and how much it will run me. [img]graemlins/bowdown.gif[/img] :D
cam question
First how much power do you want and how far do you want to go with mods?\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
Crane makes 2 mechanical cams, the smaller is a mean street cam.
I think they go for about $200.
Mechanical cams are bad @$$.
There larg Mech. cam looks unstreetable.
Or stay hyd cam and get a crane 272 cam like me it has 216*/228* dur and .454''/.480'' lift, it is the biggest hydraluic cam they (crane) make for the 3.4.
Comp makes one a little bigger than that it's like 228*/228* duration (lift is ??? by me) but I dont think the fuel injection intake can flow enought to feed it.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
Bigger isn't always better unless you do some porting. If you wanna do heads at the same time I'd say go with the big one :D , if not, go with something a bit more mild. I put the Crower Baja Beast on my Hybrid and it dropped my 1/8 mile time by .6 seconds. I'm running 15's now no doubt. If you wanna go all out, get some hedders, port the heads, and get a 5 angle valve job, new springs, locks, 1.6 rockers and a cam with as much lift and duration as the computer will allow (you'll prolly run mid-low 15's). All of that will set you back over a grand (unless you do the work yourself). The 3.4 has potential, so don't think you don't have a chance of making power.MODS:<br />3.4,Crower cam, K-motion valvesprings, Heddman Longtubes, BBK AFPR, Accel Coil, 36mm/23mm Sways, Boxed LCAs/Panhard bar, Mutant Nitrous wet kit, Mr. Gasket Cutout, 10.02 1/8 mile at 67.2 mph UNTUNNED no spray
im not for sure but i think the crower baja beast is a little bit on the mild side. the GT2 cam from ZZP performance is a good cam lots of lift. boring the cylinders isnt usually used to accept a larger cam. the main things you want to upgrade is lifters, pushrods, rockers, springs, Port and polish, 3-5 angle valve job, throttle body, etc. and tuning1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
check it out http://www.cardomain.com/memberpage/576233/41995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
im runnin the big comp cam its running way rich down low though i wouldnt suggest it if you had to drive it daily... which i do....its rough big SOTP gain to me but i will get some times and maybe a dyno... i want to put my aluminum heads on now though!! Anyways go with something in the middle a little lope a nice idle and a little power. I Hope i helped a bit. Later,
DakotaSlammed, Cammed, Stalled, Rollin on ZR1\'s and the sickest exhaust you have ever seen on a camaro Z06 style whoo whoo.<br />I\'m the reaper dude, ask ur people dude. I move
cam specs on the site are duration 226 236 and lift is .463 .474 but i used a split ratio rocker arm and bumped it to .494 intake and left the .474 exhaust. It is running much better now. I dropped my fuel pressure to where i am just a little bit rich under WOT and i changed the spark plugs since they were fouled under the first run with 24lb injectors... Its strong and sounds great.... only problem is its still a bit lopey for the street the stall helps a lot so its all good. Just adding the specs for anyone who wanted to knowSlammed, Cammed, Stalled, Rollin on ZR1\'s and the sickest exhaust you have ever seen on a camaro Z06 style whoo whoo.<br />I\'m the reaper dude, ask ur people dude. I move
