Don't run it no more. Do you have oil pressure? You could have rolled a cam bearing. That would be real bad. Plus I tink that the 97's have a limp mode on them so when someting goes wrong it shut off down to two cyl. to get you off the road. Check your oil for small aluminum shavins that would =cam bearings
car not running... need help asap..UPDATE!!motor is gone
Yea, it's quite possible from all your recent cam swaps that a cam bearing got knicked up.. You have to be EXTREMELY careful when removing and installing the cams.
Horse_Hunter, great thinking!
Mike, your heads were never removed... perhaps you blew another gasket or one didn't seal properly, like lower intake to head or front cover.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
My car did the same thing mike but i caught it after driving the car for like no more than 20 miles and i redid all gaskets and flushed the motor with motor flush and then ran 3 sets of oil through it to clean it all out. and car has run great since. I am really sorry man. Are you gonna upgrade or are you gonna go back to the six.<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
yea one of slackers intake gaskets leaked coolant and we got a nice kinda of like real old milk think goin on in the motor
next day we did it again had to get all new gaskets and bolts
hrmm why not get a motor for 400-500 put the cam in it but right this time then drop the engin in? it will only set you back about 800 for gaskets and all
hehe bring it to texas [img]smile.gif[/img]
When assembling the upper and lower intake, DON'T forget to put those rubber o-rings in!Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
the motor is most likely shot.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
magnus are you talking about the orange rings? can an upper intake gasket be reused? im asking because my car had a brand new felpro and it was never ran, and since someone dropped a bolt down the intake i had to take it off, can i reuse my gasket? i know i need a new head gasket so i bought one i was told i can reuse my upper intake gasket and my valve cover gasketLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
you should be fine re-using it if its never been heat cycledKeith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
