2.8L specs - FirebirdV6.com/CamaroV6.com Message Board
2.8L specs
  • 2.8L specs
    I think this is a question for the advanced side of 3rd gens. Can anyone tell me what the stock piston diameter and the stroke measurements for a 2.8L? And if this is not for this forum let me know. Thanks
    -Buck
    1989 RS 2.8L MPFI - 5SPD<br />All Original
    3.5" bore, 3" stroke
      Thanks. So if i bore it 30 over it will be a 3.8" bore with 3.0" stroke and that would make it a 3.4L 205CID. is this correct? i wonder how many horses this would produce?
        I think that it would make 163@4900. does this sound right?
        -Buck
          The stock 3.4L V6 with a 3.622 bore and 3.312 stroke puts out 160Bhp so I would think your figures are probably pretty close.
            bore & stroke may be closer to a 3.4, but you still need a new cam. There are 2.8-3.1 & 2.8-3.4 stroker kits available.
            2013 Ram 1500 Big Horn
            94 comero 3.4
              <blockquote>quote:</font><hr>Originally posted by Buck89RS:
              Thanks. So if i bore it 30 over it will be a 3.8" bore with 3.0" stroke and that would make it a 3.4L 205CID. is this correct?<hr></blockquote>
              Not Correct! Your math needs a little fix...
              30 over is 30 thousandths of an inch or 0.030". The original 3.500" bore would become 3.530" if bored 30 over. The cylinder wall thickness in the 2.8/3.1 block is less than 0.120" so there is a limit to how far it can be safely bored.
              [ June 01, 2003: Message edited by: MountKidd ]</p>
                Thanks for correcting me, i fell dumb right about now considering all through college a made A's in math. Thanks
                -Buck
