I want to port and polish my TB. I ran a search but did not find what I was looking for. Does any one have step by step instructions with pic's? what are pro's and con's? Also what tool's, parts & materials do I need to do the job?
Thanks in advance [img]smile.gif[/img]
[ May 29, 2003: Message edited by: calvo ]</p>
1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
They are already smooth from the factory. The only polishing you do to it is for visual affects really..
The ONE thing I can think of that could be done on a 99+ is grinding down that front lip above the MAF.. You have to be careful though because its shallow.. and maybe take some epoxy and build a little ramp for it..
Hummm I might be interested in something additional to be done with my TB...I have the 99 I agree that to me The damn thing is already smooth....But always up for suggestions :D
Eric
Eric
2005 Mustang 4.0
1996 Camaro Conv
2000 Ford Excursion
I agree with the smoothness part as far as there being any big burs or what nots but it is not ported or polished stock, air flows mucho better over a polished surface than a stock smooth surface. I would just take a lil off the top and polish it up.
Does any one have any pic's of a 99+ P&P job?
I ordered the Mini-AFC should be here tomarrow to make up for the lesn condition? There is not much to do maybe I will jus polish it up a lil' jus for Kicks and giggles [img]smile.gif[/img]
also I will need a new gasket cause you have to remove it from the car correct?
navyblue2000 or any one elseDid you use a felt polishing wheel or a wire brush?
[ May 30, 2003: Message edited by: calvo ]</p>
