Ok I pulled my intake today to spray some TB cleaner up the TB, changed my oil and that's it. i put it back together and now my car whistles so loud it hurts my ears.
symptoms:
LOUD whistle at idle
idles high (just under 2K)
stops whistling when i give it gas
Am i screwed? ba$tard 3.4.... :mad:
[ October 11, 2002: Message edited by: C.Palmer ]</p>
1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
Feed it crackers and see if it still whistles [img]redface.gif[/img] :D Like everyone else said, you have a leak somewhere.
Kevin
1998 Black Z28<br />1995 Black 3.4 (@#$$%* ex took it!)<br /><a href=\"http://photos.yahoo.com/bc/nikkev1/lst?.dir=/New+Camaro&.view=t\" target=\"_blank\">Pics</a><br /><a href=\"http://www.scfyb.com/phpBB2/\" target=\"_blank\">Carolina Board</a>
vaccum leak at the plenum (between the Y-shaped thing and the intake manifold)
i ripped that damn gasket so many times i cant even count. time to take it all apart again and fix the leak.
use some silicone (the High Temp RTV) if you cant get a new gasket from a GM Dealer. you can also get the gasket in an upper engine kit from like pepboys or autozone. it'll cost you more than just going to GM tho id think.
Use a vaccum cleaner hose or something similiar. Put one end up to your ear and the other move around the engine bay. Its the easiest way to find vaccum leaks.
I am confused....Did you take off your INTAKE? or did you take off the plumbing and filter, etc that leads up to your TB and then intake? If you actually pulled the upper intake (the big metal part), then yes check the gaskets for leaks...if you have the whistle after just removing the, let's say SLP cold air intake, then that's another(much easier) story.
