how much horsepower and torque will our stock crank handle before it crumbles.
stock crank ?
stock crank ?
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
is it for 3.4 or 3.8?\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
from what I can figure, i am making 250-255 hp and maybe 260-270ft.lbs at the crank with my cam and driveshaft injectors and all the rest of my mods. I have a nitrous cam and that is what im planning to do next. will a 100 shot with 3.73 gears be too much???96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
well over here in auz we have the same 3.8litre v6s in rear wheel drive gm holdens and have had one just make 500 rear wheel hp @20psi. and this still runs stock crank/internals. how much hp do u think a preped crank could run? eg-nitrided and polished? also how many steel cranks are there out there for the 3.8s and some web sites would be help full.
Originally posted by CrEaTiVe PuNkA:
well over here in auz we have the same 3.8litre v6s in rear wheel drive gm holdens and have had one just make 500 rear wheel hp @20psi. and this still runs stock crank/internals. how much hp do u think a preped crank could run? eg-nitrided and polished? also how many steel cranks are there out there for the 3.8s and some web sites would be help full.www.turbov6camaro.com
1997 3800 Series II Camaro
I think with the stock bottom end internals it MAY be possible to get 500 hp, but you are really pushing the limits of the piston assemblies with that kind of psi and hp. As for the crank, I have heard very few people breaking a crank that has been taken well care of and had lots of hp turning it. I don't think anyone makes any other aftermarket crank that I know of, at least one that is going to work better than stock.
If you are wanting to strengthen the crank, I suggest cryo-treating. Be pretty difficult to break one after treatment.1995 Pontiac Firebird
prove it the only 3800 i have seen over 500 to the wheels is INTENSE's turbo car and that's a fully biult motor, i don't think the stock motor could do 500 HP with stock cam/injectors an NO tunning1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
last time i checked the cam rotates too and it is inside the motorwww.turbov6camaro.com
Stock internals means you don't crack open the engine and replace ANYTHING that moves.
500hp+ on stock internals = [img]graemlins/bs.gif[/img]
20psi on 9.5compression with no internal support = [img]graemlins/bs.gif[/img]
You won't have to worry about your crank breaking. ZZPs ghetto lightened 4.1 crank could take 375rwhp and its just a hack to pieces stock crank lol. Since yours in stronger my GUESS would be upwards of 450rwhp may make it break.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
were you get GTP crank fromwww.turbov6camaro.com
Originally posted by viper04af:
were you get GTP crank fromMatt
1998 Mystic Teal Camaro M5
Timmy isn't but AllTheGoodNamesAreGone was probably talking about aussie boy.
Either way to answer the question Timmy your crank will handle that amount of power without a problem. If a butchered stock crank can handle 375rwhp I'm sure your unbutchered stock crank can handle 350hp.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
