I heard about the LS1 destroked to a 302 and I think that would be an awesome motor! Anyone know the specs, I am thinking about building one up. Where did they get a crank to destroke it? I prety much inherited a 69 RS Z-28 with the 302 and I would like to have a newer camaro with a 302 also, just for fun. Then I could compare old school high performance with new tech first hand. ANyone have details on this motor, let me know.
Anyone know the specs on the LS1 302?
Thats a pretty damn nice inheritance. A '69 or '68 Z28 is my favorite car.
But anyway, I saw the LS1 302 at the SLP customer appreciation day and it was incredible. I was given the impression that GM performance parts can sell you all the components you need but you have to assemble the motor yourself.
It would cost but it would be pretty damn sweet.
I'd check out some of the LS1 message boards.
[ October 16, 2002: Message edited by: jonny985 ]</p>1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
As far as a crank goes, does it use a production piece or a performance part?? They talk about heads, pistons, rods, block, but I didn't see anything about the crank?
[Edited initial post]
Did some searching on the truck parts. I had the bore/stroke relationships backwards. The 4.8L and 5.3L share the same bore. 4.8L has a shorter stroke. 5.3L and 5.7L share the same stroke, with the 5.7L having a larger bore.
5.7L - 3.900bore x 3.62stroke
5.3L - 3.780bore x 3.62stroke
4.8L - 3.780bore x 3.26stroke
Using a 5.7L block with a 4.8L crank is around 311ci, or 5.1L. I am looking for some more info on the 6.0L but the vortec site is down currently.
[ October 17, 2002: Message edited by: Backfire ]</p>
Why destroke the LS1? You may be able to rev higher but you won't make as much power. :(Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
But wouldn't it be fun to go after 5.0L mustangs with your *ahem* 435hp 5.0L? :D2002 5-spd NBM Camaro
Details: www.1lev6.com
Found one site that said they used a 3.84bore x 3.286stroke, which is the 4.8L crank. That winds up at just over 302ci. Don't know where the block came from, might be able to massage a 4.8L/5.3L block that large. That would be what, about .060 over? I know there isn't a ton of room on those LS1 blocks to work with, but I think that setup sounds doable.
Go over to LS1tech.com and search for 302 in the internal engine forum. There are a couple of posts concerning this.
[ October 16, 2002: Message edited by: Backfire ]</p>
The 302 (the original 302) makes gobs of hp, not as much torque (but still respectable), and winds up quicker.
AZ3.8...is that RS numbers matching???? If it is, you've got one sweet inheritance, man, congratulations.....take really good care of her (DON'T do anything to it that can't be easily reversed, PLEASE!!!!!) :D :DWife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
Its all original, my dad bought from the original owner many years ago. The guy was going to race it. It has 10.5:1 pistons, AFR heads all the goodies. Race suspension, roll cage with original interior. RS (Hidden headlights) and z-28 (302) packages. The guy he bought it from had it all apart to paint and tub, but he got called into the service and had to sell it in peices. Oh, and he never got to tub it, so its original and not chopped. He's had it since I was little, and we had plans of restoring it (he's a mechanic) but we needed a good garage. Well he's building one now! Can't wait. But nobody know where the LS1 destroke crank came from eh? I know westech auto built it, but they don't have much info. Keep me posted if you learn anything.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
Oh yeah, check on the gm powertrain, they have a new 5.0 liter out.....that's your best bet. The only thing is, Chevy has completely redone all the bores and strokes. The original 302 had the bore of a 350 and the crank (stroke) of a 283. The new ones are all out of wack, even the LS1 has a smaller bore and a longer stroke, it's a totally different beast from the original 350s.
Hope this helps, and good luck with the car.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
