For the life of me once i tighten down the last connecting rod bolts the motor locks up i am truening by hand with socket. 5 out of 6 can be torqued down and as soon as i do the 6th it locks i double checked that all bearings are .010 undersized andchecked all threads it just wont work i am so freaking confused and arngy. Please any ideas.
Man i quit this is the worst engine rebuild ever
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
When we installed the cam in dad's car, the pushrods were too long, and the valves ended up hitting the top of the piston. Just turning it by hand made it feel like it was locked up. You may want to check all the specs on your parts and make sure nothing is binding up. Since you're putting in connecting rods, I assume the motor is out of the vehicle. Look in through the spark plug holes and see if you can see the piston hit anything. Will the motor turn back the other direction? Just check it all again man.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
motor will not move a inch once the last connecting rod it torqued it is completly frozen but if the connecting rod is loose it will spin like butter.<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
If you only have .001" clearance on the rods, thats a little tight anyways. You'll need atleast .002". I'd suggest pulling it apart and having all the main and rod clearances checked just to be sure and to also save you the hassle of having to go back through it.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Would a shop for some reason grind all but one crank jornal to .01 and have one at .02? its the only thing i can think of<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
Originally posted by slacker69:
Would a shop for some reason grind all but one crank jornal to .01 and have one at .02? its the only thing i can think of<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...19 hours ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....5 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.5 days ago
