Heads,Cam,Intake question - FirebirdV6.com/CamaroV6.com Message Board
  • Heads,Cam,Intake question
    Sure, at 38K miles its just broken in good.
    Heads
    Stage 2: $975 plus refundable $120 core
    Stage 3: $1300 plus refundable $120 core
    Ported upper and lower intake set: $550 plus $100 refundable core
    Cam: $425
    We offer these as PowerPaks to include the heads, intakes, and cam:
    Stage 2: $1900 plus refundable $200 core
    Stage 3: 2200 plus refundable $200 core
    We also have forged pistons for the GM3800 series 2 L36 for $675 which includes rings, pins, and lox at 9.4:1 compression ratio.
    worth it?
    i asked about a group purchase if anyone else is interested,
    i was thinkin about the powerpak either 2 or 3 depends on cash flow, but is it worth it and do i need to do any other mods for these?
    i have a 2001 3.8 V6 38k miles
    how much power do you think itl make?
    $425 for a cam is buttrape by any means.
    Porting intake manifolds is really easy to do.
    Heads are harder, and probably worth the money.
    I would just get the heads, then port match the lower intake to it, then match the upper intake to the lower. By a cam from comp cams for about $300 and pop it in. :D
    1997 Dodge Viper GTS
      http://www.abbottracingheads.com/gm3800.html
      Ported Upper / Lower Manifolds: $300
      Ported Cylinder Heads, Stainless Valves, Flow Benching: $1500
      Custom Ground Camshaft: $300 (the price it should be)
      Plus the have lifters, pushrods, gaskets sets, and everything else you will likely need. You won't need forged pistons for a naturally aspirated motor with no nitrous.
      1997 Pontiac Firebird 3.9L<br /><br /> - TSP Dyno Tuned<br /> - Bored 0.040<br /> - ARP Rod Bolts / Head Studs<br /> - Custom CAI<br /> - Pacesetter Ceramic Headers / !Cat<br /> - 3\" Catback w/SLP Firehawk Muffler<br /> <a href=\"http://www.cardomain.com/memberpage/649312\" target=\"_blank\">http://www.cardomain.com/memberpage/649312</a>
        SSM does great work, but don't get the whole powerpak. Just get the heads and go elsewhere for other parts.
        Matt
        1998 Mystic Teal Camaro M5
          anyone intrested in a group purchase he said if we get 6+ well get the stage 3 for the price of stage 2
            if i had the $$
              anyone intrested its a killer deal
                I havent seen any cars with results to back up SSM parts yet.
                I'd go with Abbott if I were you.
                2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
                  I don't agree with that at all. Abbott is great, but don't go saying SSM is no good because the few people that have used their stuff haven't gotten amazing track times.
                  I ran a stock suspension to a 14.5 @ 96 untuned with the clutch spinning for a 2.2 60' at a 2100' density altitude on stock 3.23s. That's pretty damn impressive to me.
                  For that matter, your time isn't that amazing either, but I'm not gonna blame Abbott.
                  Matt
                    14.5 is impressive for a 98 3.8 w/ 3.23 (unstock tho)
                    SSM has gotten good times. maybe not their customers ....
                    [ November 07, 2005, 06:03 AM: Message edited by: ezrollin ]
                      Originally posted by ezrollin:
                      stock suspension dont matter cause your 3.23s (no trac probs)
                      Apparently you lack experience in the subject.
                        Magnus ran the times.
                        Its only a matter of the right person, with the right car buying them.
                        I have not seen any proof that either company does better work.
                          I'll let you know when I get all done.
                          I got the SSM heads and manifolds and a pretty big cam, working on the tune now(HPTuner & WBO2). Cam not from SSM, btw.
                          I know for a fact I need a stall and that's going to limit the ET improvements.
                          Won't matter for the dyno though. Will get that towards the end of the month.
                          01 Camaro A4 Convertible
                            Originally posted by AZ3.8Camaro:
                            </font><blockquote>quote:</font><hr />Originally posted by ezrollin:
                            Apparently you lack experience in the subject. </font>[/QUOTE]Exactly. I can spin 'em with 3.08s in the cold.
                              In regards to the cam head intake question....i posted nearly half a year ago regarding a research project im doing on head work in comparison with all the aftermarket porters that work our heads. I am nearing completion as I have not had a lot of time to work on it. I will post it as soon as i finish it.....It addresses flow comparison, efficiency, valve size and velocity. Also I have built in a bit of cam application as well. It will be a useful tool. Any questions let me know
                              SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
