ok, so this isnt happening or anything, duh. im just wondering how much it would cost to change a V6 over to an LT-1 Corvette engine . . . including all parts needed and installed
The belt driven accesories are monthed differently and wont fit, so you would have to get an LT1 long block from one(The only benefit of doing this is 4 bolt mains instead of 2 and unless you plan on breaking the 450-500 HP barier its worthless) then all the belt driven accories and harness from a Camaro, then k-member, suspension, plastic fuel lines, fuel pump, guages, Transmission, cross member, radiator, and hoses. Price to do this? Hard to say.
Doing a corvette LT1 over a Camaro LT1 will cost substantially more with no power gain and and a lot more work. Not worth it just for 4 bolt mains IMO.
